Rebuild display option
Displays can be rebuilded to their initial state (the preview that is created when adding a new display). This is useful in cases of changing/adding some channels in Channel setup section. Channels are not updated by default, that is why they need to be rebuild.
Example for FFT analysis:
* One channel is added for FFT analysis:
Predefined display for FFT analyzer with selected channel applied:
Going back to measure and selecting 2 more channels will not update the display in Measure mode, that’s why it is needed to rebuild display:
Rebuilt display:
Note that if you rebuild display, it will as well change to the initial layout. That means if some additional widgets were added and the layout of the display and widgets was changed, it will reset to the initial state.
