ENI Export
Introduction
ENI Export extension lets you export the ENI (EtherCAT Network Information) files that are often used in the process of configuring controllers with EtherCAT support that are used in various types of test benches.
Supported devices
Version 1.5.0 supports the following devices:
- SIRIUS: single and rack versions of CD, HD, and HS
- KRYPTON: 3/6xSTG, 4/8xACC, 8/16xTH
- IOLITE/OBSIDIAN R8/R12: 8xTH, 6xSTG 8xRTD, 8xSTGS, 8xACC, 8xLV, 8xLA, 8xLVe, 4xCNT, 16xAO
- Other: ECAT-REPEATER
Version 1.6.0 adds support for:
- KRYPTON: 16xDI
- IOLITE/OBSIDIAN R8/R12: 4xHV, 8xLVe, 16xLV, 16xLA, 4xCAN-FD (no data)
Version 1.7.0 adds support for:
- OBSIDIAN GATE in native Dewesoft RT mode (requires DewesoftX 2026.3 and OBSIDIAN firmware 2026.3)
- IOLITE/OBSIDIAN R8/R12: 8xTH-HS, 8xRTD-HS, 4xUNI, 6xUNI, 8xUNI, 32xDI, 8xDI 4xDO, 32xDO
- KRYPTON: 8xTH-HS, 16xTH-HS, 8xRTD-HS
Installation
To add the extension follow the Add extension installation procedure .
Channel setup
After you have added the extension and have the EtherCAT devices connected and set up in DewesoftX, you can go into the channel setup and select the ENI Export tab to access the extension’s setup interface.
The interface consists of three sections:
- Setup
- Channel list
- Advanced settings
Setup section
The setup section contains the following:
- ENI file destination,
- Scale/offset file destination: includes scaling information of selected channels for manual configuration of the controller,
- Operational mode dropdown menu: allows you to select the mode based on the connection/usage (Standalone mode - controller only or Dual mode - DewesoftX and controller running in parallel) and synchronization (DC Sync, SM Sync, ECAT PPS SM Sync),
- Export ENI file button: exports the ENI file,
- Show advanced options button: shows/hides the advance options panel.
Channel list section
The channel list section contains the following:
- Up/down buttons: move selected device up or down in the channel list,
- Export channel buttons: let you select which channels will be included in the ENI file.
Advanced options section
The advanced options section contains the following:
- Cycle time: defines the EtherCAT cycle time that should be used on the controller.
- Sync0 shift: if DC sync is selected, it defines the distributed clocks Sync0 shift time.
- Automatic offset compensation: enables automatic offset compensation available on Sirius instruments in bridge mode, which removes the need to export a new ENI and/or Scale/Offset file each time the inputs channels are balanced. For the offset to be corrected, power on default needs to be set after every change of offset or zeroing.
- Enable MTS compatibility: makes the ENI file compatible with MTS 793 software and adds channel scaling information in form of comments, which lets MTS software set up the scaling automatically when the controller is set up in dynamic mode. When the controller is running in static mode, the Scale/Offset file provides scaling information in the form of full scale min/max values along with the additional gain of (optionally) offset that should all be used as calibration factors in the configuration software.
- Enable optional PDOs: enables additional status channels (EtherCAT frame and sample counters).
- Enable RefClock Functionality: sets first input device as possible reference clock device. Needs to be disabled for compatibility with MTS 793 6.2D and newer.
DCOM Integration
The plugin supports triggering an ENI export via DCOM using the following command:
CMD:ENIPLUGIN.EXPORT
Note that the file names, settings, and exported channels must be pre-configured in the plugin setup window prior to triggering the export.
